anyone boosted a vanos m50?
  • ogbimmer
    • Jul 2010
    • 936
    the more I read the more I find out the vanos m50 and the nv m50 are actually really different. but theres no going back now, so my question is has anyone boosted and tuned a vanos m50? what kind of number are you making? How hard was it to tune? I have a Ms3 for my build with really aggressive cams, ported and polised head with 5 valve head job,thicker metal hg, arp studs, forged pistons and rods. should my motor be able to take 25psi, and any idea about what I should make
    " WHY DO YOU NEED 300HP TO DO THE SPEED LIMIT?"
  • Good & Tight
    • Apr 2004
    • 2057
    My bone stock 2.5 made 220rwhp at 7 psi on a mustang dyno, NickG tuned.
    With your hardware and a good tune at 25psi you should be north of 500hp easily.
    What type of manifold you plan to run? I have T3 and T4 top mounts available.
    Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
    ____________________________
    E-mail Panayiotisx2@gmail.com
    Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
    • ogbimmer
      • Jul 2010
      • 936
      I got a twinscroll t4 Im running. so Im getting a manifold made at the shop. I need two wastegates though
      • ogbimmer
        • Jul 2010
        • 936
        how was it tuning with vanos?
        • Good & Tight
          • Apr 2004
          • 2057
          You can also run one wastegate. What are the specs on the turbo, brand?
          • Good & Tight
            • Apr 2004
            • 2057
            Had the stock ECU tuned for a draw through set up. I think the new MS can run vanos.
            • dark89e30
              • 263
              Draw through setup?
              • Good & Tight
                • Apr 2004
                • 2057
                Originally posted by dark89e30
                Draw through setup?
                Used the stock MAF in front of the turbo.
                • matt
                  • 3732
                  Draw through setup?
                  MAF on the inlet side of the turbo.
                  We do a blow-through MAF setup that runs really well.
                  • ogbimmer
                    • Jul 2010
                    • 936
                    Thats good to hear :) I will get the specs off the turbo as soon as I get back in town. Its been in a box so long sitting I have temporarily forgot about it.
