holset h1c
  • mrmckie
    • 728
    holset h1c
    hail to the turbo gods..lol
    I have a 86' 325es that i plan on turboing but I'm new to the turbo world. After some research i've decided to go with a Holset seeing that most BMW folks use them and have gotten good results. I've come across what looks like a pretty good deal on one of these turbos brand new on CL. From the ad here's the desc of the turbo:
    "It is 3" Compressor inlet, 2.5" Compressor outlet, and 3" V-Band Turbine outlet in a twin-scroll 18.5cm turbine housing. It is the 8 blade compressor wheel version"
    I'm going 2.7 stroker. I have a seperate ETA block and "I" head that i will be sending to the machine shop to be cleaned and reassembled with stock internals. I was also considering o-ringing the block w/ a oem head gasket.
    power-wise i'm shooting for 260-300whp on low boost and close to 400whp with the boost turnt up. I don't mid a little lag but would like a turbo that provides consistent power/response across the RPM range
    Would these turbo specs work for the power i'm trying to attain? Also is anyone still using this turbo and what are your impressions. I know i left out alot but just wanted a little input..
    "I came into this world, not chiefly to make this a good place to live in, but to live in it, be it good or bad" -Henry Thoreau-
    1991 318is - the cruiser
    1989 325i - the rats nest
  • lifeiskaos
    • 1709
    i used one with a 2.7 stroker, but a 12cm housing. i'd recommend a 14cm housing
    • redsubdivisions
      • Feb 2011
      • 1762
      I am using this on my M20 stroker motor that I am currently building. Glad to see someone going a similar route as me!
      However, I was in the car with this same exact turbo and motor and I will tell you this fucker pulls nice. 3 people in a car at that, passing some douchemaster Porsche salesman in the process and completely ruining a sale for him. haha.
      1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
      2012 Passat TDI - DD Duty
      2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
