Wideband, stock o2, questions
  • jaywood
    • Jul 2010
    • 4528
    Hi. Got a wideband o2 sensor. Need some wiring help. Here's what I know (correct me if I'm wrong)
    Stock o2 connectorfdfdfdfdfdfd LC-1 wires
    Yellow --------------------------- White
    Black ---------------------------- Brown (bold because the brown wire is for analog 2, narrowband. analog 1 is defaulted for wideband signal.)
    Brown --------------------------- Blue
    Green/blue ---------------------- Red
    How does that look?
    Also, how would I wire it in? Do I need certain "plugs" to go into the harness, or could I just snip the wires and solder them in? Do I keep the stock o2 plugged in (at the harness) and snip the wires on that? Or how does that work...?
    Thanks guys!
  • einstein57
    • Jun 2007
    • 10780
    I wired mine up independentally but that was overkill. The easiest way is to take an old O2 sensor and snip it to use the harness. That way you can easilly make changes in the future.
    www.gecoils.com
    • MC Hammered
      • Jul 2008
      • 2076
      You are supposed to weld in a bung and use a separate o2 sensor and leave the stock o2 sensor in the car alone.
      Your LC-1 should have come with its own 02 sensor in the package.
      My 1989 e30 s52 Touring... this is Betty
      My 1989 325i vert (sold)...this is Nina
      My 1991 M5 (sold)... this is Veronica
      Photo comparison: OEM vs aftermarket windscreen for a convertible
      • jaywood
        • Jul 2010
        • 4528
        As far as I know, there is no point in keeping the stock o2 sensor in the bung when you have a wideband taking it's place. The wideband can send the ecu a narrowband signal. That's what the brown wire is for.
        • einstein57
          • Jun 2007
          • 10780
          That's one of the things I like about the LC-1 over the UEGO. Oem sensors are way overpriced on the e30.
          www.gecoils.com
          • Jaxx_
            • Dec 2009
            • 1880
            Stupid.
            your wideband controller should be able to output a narrowband signal to the ECU. Use the factory bung.
            • MC Hammered
              • Jul 2008
              • 2076
              I didn't know that the e30 used a narrowband input.
              My suggstion came from my experience with audi setups where you can't use the stock o2 as the ecu will throw a code.
              • Jaxx_
                • Dec 2009
                • 1880
                very few select cars have wideband inputs. you'd better believe that a stone age EFI system from the 80s doesn't. Yes, VAG cars can sometimes feature OEM widebands. So do some Nissans. And if I recall correctly, new fords.
                If you're going to speak up please make sure you have correct info, otherwise we get stupid threads that amount to about 50% of the posts on r3v.
                • MC Hammered
                  • Jul 2008
                  • 2076
                  Thanks for the slap on the face for trying to assist. As I stated, my post was borne from my knowledge of selling and installing LC-1's in a VAG vehicle.
                  I will make sure to have my info certified by an e30 guru before posting up any relevant information next time.
                  • jaywood
                    • Jul 2010
                    • 4528
                    No need to be arguing guys. If I want to keep the stock o2 in there I could. That could be my narrowband signal and the wideband wouldn't hook up to the narrowband output thingy. There would be a free wire.
                    Thanks for the help so far guys, just need a little clarifying on my wiring diagram.
                    • EthirtyIS
                      • Feb 2011
                      • 270
                      hey, jay did you get your wideband 02 working with your motronic
                      Proud Owner and Operator.
                      • jaywood
                        • Jul 2010
                        • 4528
                        Sort of. I ended up not using the power/ground/ground from the stock o2 sensor harness. I was getting readings of 19 afr at idle so I figured there was something wrong with the wiring. I ended up using a switched +12v for the power (right next to the fuse box) and a shock tower bolt for the 2 grounds. It now works as it should. Keep in mind, I still have the yellow wire coming out of the wideband controller hooked up to the motronic (black wire in the stock o2 harness, o2 side)
                        • e30newbie1212
                          • May 2011
                          • 110
                          All of my research into this, including reading the manual PDF from Innovative (which talks about this) has been for the MTX-L Wideband Controller. But it is easily possible to simulate the stock using analog 2 output from the controller. The programmable limits of the analog outputs is 0v -5v, which is customizable by you. This is perfect for us since narrow band is 0v to 1.0v. From Innovative, in stock form, the analog output 2 is 0.1v to 1.1v, with 0.1v equaling 14:1 AFR, and 1.1v equaling 15:1 AFR. I will be receiving my MTX-L tomorrow, and will be using the analog 2 output stock at first, and if there is issues I will go into the supplied software and adjust output values as needed to get the AFR looking good. I hope that helps some, if anything is wrong I apologize as I am no expert.
                          GetRealWeird.com
                          For all your daily entertainment needs
                          • EthirtyIS
                            • Feb 2011
                            • 270
                            mines working but my gauge took a crap, i wired it in according to the pdf file, and spliced the yellow (lc1) to the black on the sensor side of the o2 connector, then grounded the white's coming off the sensor side of the o2 connector. that worked out well for me, the gauge was reading between 14.5-14.8 at idle, then under 5psi at 3800 rpm it hovers around 15.1, then when shifting to the next gear, it will jump to 17-19 then drop back down to 13-14 then go back up under boost.
                            that just about were it should be, id like to get that boost afr down, but its not bad for ebay chipped motronic, an fmu and a turbo set up.
                            • einstein57
                              • Jun 2007
                              • 10780
                              Sounds kinda lean sir. 14-15 afr readings under load are lean even for NA.
                              www.gecoils.com
