HELP car won't start
  • dmjensen
    • Jan 2011
    • 804
    after i resealed the whole motor, and put in new headbolts for my turbo build i have all of my turbo parts together im using a miller chip and maf and the car wont start.
    it cranks over fine, when you turn the key to the "on" position it has a check light so you know the chip is comunicating right. but i have no spark to the plug wires.
    please help
  • dmjensen
    • Jan 2011
    • 804
    also my coil has 12v so it is not the fuseable link
    • E30_fiend
      • Apr 2006
      • 7348
      do you have fuel?
      The coil maybe be getting 12v but is it putting it to the cap?
      • BMWZ318is
        • Nov 2008
        • 102
        do you have good grounds to the motor and do you have fuel pressure cause if you have no spark or fuel pressure then you may not have any tunes loaded onto the chip.
        • dmjensen
          • Jan 2011
          • 804
          I had a bad crank sensor. But now the car is getting too much fuel on the tune and wont start haha
          • dmjensen
            • Jan 2011
            • 804
            im running some volvo injectors i got from djbutchug, they're bosch green tops. he told me they were 32lb and when i part searched the number some said 42 and others said 32. are those too big of injectors if im only going to run 8 to 12 lbs?
            • BMWZ318is
              • Nov 2008
              • 102
              32lb should be fine im running 8lbs of boost with 30lb injectors you need at least 30
              • BMWZ318is
                • Nov 2008
                • 102
                glad you got it running tho
                • dmjensen
                  • Jan 2011
                  • 804
                  it ran once but now it won't start up again, im going to take out all of the plugs and clean them because i took one out earlier and it was drentched in fuel.
