Hick-up in turbo m20
  • jaywood
    • Jul 2010
    • 4528
    Hi. Just drove my turbo m20 for the first time. Here's my setup:
    T3 turbo
    3" exhaust
    Wideband lc-1
    30lb injectors
    Turbo chip
    Adjusted AFM wheel
    NGK plugs
    ~6 lbs of boost
    External wastegate
    Here's my problem:
    It starts up fine. It doesnt idle too well before it's warmed up, but once it's warm it idles good (most of the time). There is a small vacuum leak that I know of. It's the little hose underneath the intake manifold. I'm not sure of the part #, anyone know what I'm talking about? It's not just a hose, it's shaped kind of like hook or something. Anyway, on to more problems. The first time I drove it, there was power throughout the rpms. The next time I drove it it felt like there was no power ~4k rpm (2nd gear pull). This was not WOT. Maybe 3/4 throttle. I don't have an RRFPR (will be getting one soon). What could be my issue? Is it not getting enough fuel?
    Any help would be great :)
  • BMWZ318is
    • Nov 2008
    • 102
    i have the same idle issue you do need a rrfpr you should pull your plugs and see what they look like make sure your getting enough fule what engine managment system are you using?
    • jaywood
      • Jul 2010
      • 4528
      It's a chip that came with a kit I bought. It's a bosch turbo chip.
      • einstein57
        • Jun 2007
        • 10780
        The 173 ecu is a self learning ECU. It will take a couple days for it to adjust to the #30 injectors. But having a vacuum leak does not help. The hose your talking about is for the check valve on the charcoal canister. Just pull it off and replace it with a straight piece of vacuum line. What were your AFRs when you were boosting with no power? Did you pressure check your charge pipes?
        www.gecoils.com
        • slammin.e28
          שמע ישראל
          • 12054
          I hate when rednecks get in my engine too.....
          • blueapplesoda
            • Dec 2005
            • 1904
            You NEED that rrfpr.
            btw, get some real engine management when your done playing with kids toys.
            • blueapplesoda
              • Dec 2005
              • 1904
              :rofl:
              • jaywood
                • Jul 2010
                • 4528
                Didn't pressure check my charge pipes, I might have to do that though. Ok cool, I will do that when I get home from school. My Afr readings are all over the board. It says it's idling at 19 now, but before it would idle at 15. So I think I have a bad ground on the sensor. I wired the lc-1 into the stock o2 connector so I don't think that's doing anything other then giving me trouble
                • jaywood
                  • Jul 2010
                  • 4528
                  I can't find anyone who's getting rid of their RRFPR. Where can I get one?
