Lately ive been noticing ive had high oil pressure while driving, is this normal or is there something im missing?
is high oil pressure normal?
Does it come down once the car warms up? What pressures are you seeing??IG: deniso_nsi Leave me feedback here
for pressure it shouldn't matter how big the line is unless one end of the cross or tee is going directly to the sump, an that would cause low pressure.
Maybe something is stuck in the pressure relief valve. When cold mine will be around 40, but when warm, it goes down as low as 5-10 or so. I have mine tee'd off with the oil feed on the turbo so it may read slightly low.
Im thinking i solved the problem, i had one of those oil breathr filters on my valve cover and it was smashed in the hole instead of over. So i think my crank case wasnt being ventilated because its fine now. So ill just leave the filter off for a bit.
But blueapple i think your right, thats how my pressures were before this started happening. But i know i have a leaky rear crank seal so i figured pressure should be lower than what was happening before i took off that filter
Originally posted by jaywood View PostSometimes a restrictor increases pressure as well as decreasing flow. Think about putting your thumb on the end of a garden hose. Your thumb is a restrictor. Pressure is increasing and water is shooting further.
Just a thoughtYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
