what differential gears m20b27 turbo
    i have a 2.7l stroker arrow rods stock super eta pistons arps and a stock rebuilt head ill be running a holset hx35 with full 3" exhaust and megasquirt if that helps lol dont know what gears to run in the rear will be a dd but also track/drift car any ideas?
    s3.25 :)
      what would that top out at is that still a pretty low gearing thanks for the help i have 3.73s right now
        I've seen some guys run 3.73 diff ratios on their e30. But it also depends on how much power your planning to make.
        If your planning to track/drift your car I'd probably stick with those ratios you have now and if your feeling like you wanna stretch your powerband more between shifts more then a longer ratio diff would be the way too go.
          350+ whp
