Those of you running an intercooler that blocks your radiator...
  • theox69
    • May 2008
    • 1732
    Are you guys using an electric fan to help with cooling?
    Will a pusher fit between the intercooler and the rad for effective-enough cooling?
    How much room do we have between the block and rad, assuming we do a mechanical fan delete?
    Is there a specific volume of air (cfm) I should be looking for?
    you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
  • Hey_You
    • Nov 2009
    • 963
    I have 2 extra cylinders worth of room between the block and my radiator ;)
    85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
    • devon.818
      • Feb 2011
      • 2937
      tons of room when doing a mechanical fan delete, really helps when you have to do maintenance or change belts too.
      i know frozensolid runs a intercooler infront of his radiater behind his kidney
      • theox69
        • May 2008
        • 1732
        I guess I should probably mention I have an m20.
        • e30leigh
          • Mar 2012
          • 481
          youll have tonnes of room. and i wouldnt imagine it would matter where the fan is located. its still moving air through the radiator.
          • dmjensen
            • Jan 2011
            • 805
            Get the kit from ireland engineering and put it off centered alittle more to the exhaust side of your motor and then wire it to pull air through and you'll be fine
            • Zacm829
              • Jan 2008
              • 1919
              I have mine mounted in front of the radiator, just using stock clutch fan. I haven't seen any adverse cooling effects.
              1987 325i-M60b44 swap
