Turbo sizing for a s52 m3
  • SpeedRacer85
    • Jul 2011
    • 424
    Hello guys I was wondering how this turbo will suit the s52
    Precision Turbo :: Entry Level :: Precision Turbo 5454E MFS
    HP Rating: 495
    Are you trying to put together a cost effective turbocharger system for your vehicle? Well, we've got just what you're looking for! Precision Turbo and Engine's line of Entry Level Turbochargers provide the perfect solution by delivering a high-quality turbo at a budget-friendly price.*
    This Entry Level unit features the following:*
    • MFS (Machined From Solid) 54mm inducer compressor wheel*
    • "E" compressor cover 3.0" inlet/2.0" outlet*
    • 54mm exducer turbine wheel*
    • Turbine housing options:*
    **- T3 .63 A/R with 4 bolt discharge*
    • 360° journal bearing system*
  • SpeedRacer85
    • Jul 2011
    • 424
    Is this to small?
    • Good & Tight
      • Apr 2004
      • 2057
      Are you boosting the engine with stock compression or lowering it and what type of tuning?
      That turbo will work good for 8psi on stock compression.
      Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
      ____________________________
      E-mail Panayiotisx2@gmail.com
      Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
      • SpeedRacer85
        • Jul 2011
        • 424
        I would like to lower the compression with a .120 mls maybe even a .140. What are the benifits of running stock compresion over the lower the compression. I'm using miller for the tuning. Do you think the s52 is too much for this snail? Could you fab up a down pipe for this turbo? The max on stock comp is 8psi before you need to get a thicker gasket right?
        • E30-323ti
          • 328
          I'd be looking at a .86 or even a 1.06 AR Turbine housing for that turbo on a 3.2L
          A split T4 1.06 would be my choice.
          292rwhp E30 :D
          • Good & Tight
            • Apr 2004
            • 2057
            If your lowering the compression then you can run 15psi easily and that turbo would be way too small.
            A GT35R would be an all around good turbo and put you in the 450whp easily.
            What do plan on using the car for?
            • SpeedRacer85
              • Jul 2011
              • 424
              Daily driving, autox, every blue moon the drag strip. And Otis do you make down pipes? And what about the 6262 turbo?
              • Good & Tight
                • Apr 2004
                • 2057
                I make down pipes for the 60-1 and GT35r.
                I know on bf.c their suggesting the 6262 and will be good for highway pulls but a bit laggy around town, that's my opinion though.
