Wastegate help! big confusion
  • sayed ali
    • 762
    Hi,
    I'm about buying 38mm Turbosmart wastegate
    I'm really wondering if that 38mm will be small for my set up?
    and how it's performance?
    I have an M20b25
    gt35 turbo
    42# injectors
    I'm giong to run 15-18 psi
    It has two springs inside (7psi each) = 14psi
    Also planning to use a manual boost controller
    Any help?
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
  • Hey_You
    • Nov 2009
    • 963
    Wastegates = Bigger the Wastegate, the less boost they can handle, so the 38mm should suite your needs nicely
    85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
    • Exodus_2pt0
      • 5943
      I was using a Tial 38mm on my Gli with a GT3071r at 20 psi. Should work fine for your setup.
      No E30 Club
      • e30leigh
        • Mar 2012
        • 481
        a big gate on a small turbo will result in boost falling off when the gate is opened,
        a small gate on a huge turbo with big boost will result in boost creeping
        a small gate on a small turbo is good
        a small gate on a turbo running small to moderate boost is good
        a big gate on a huge turbo running huge boost is good.
        hope that helps.
        • sayed ali
          • 762
          Well, thank you very much guys
          I decided to go with 38mm
          another quick question is which one is better? Tial/Turbosmart?
          M20B28 Turbo
          My Build Thread
          • lcoleman
            • Jan 2009
            • 331
            lol wut?
            It's highly dependent on your manifold and the w/g placement. I would tend to think that 38mm is a little small for a gt35.
            • ak-
              • 12422
              Some misinformation up in this bitch.
              Wastegates are for gasses that are dumped out because your turbo isn't using them. Your turbo doesn't know when to stop spooling so the wastegate opens when it sees the psi you want to run.
              Low psi = a lot of gasses you turbo didn't use = need big gate to release.
              High psi = turbo is using most of the gasses = gate doesn't need to be too big for gas dumping.
              Yes the turbo size matters, but that is the general concept. Your 38mm is fine for what you want to run.
              1991 325iS turbo
              • sayed ali
                • 762
                I bought a 38mm turbosmart :)
                hope to be working good
                and I'm thinking of getting a turbosmart MBC also
                M20B28 Turbo
                My Build Thread
                • e30leigh
                  • Mar 2012
                  • 481
                  im a firm believer in tial, the new mvs range kicks ass with the added water cooling and stuff i pretty cool
                  • sayed ali
                    • 762
                    I'm planning to run above 1 bar of boost and my wg spring is set at 1 bar
                    can I do this without the boost controller?
                    M20B28 Turbo
                    My Build Thread
                    • Boosted E30
                      • Dec 2009
                      • 288
                      If you want more boost then the spring pressure is set at then you need a boost controller or different springs to increase the pressure.
                      • kamotors
                        • Nov 2007
                        • 7102
                        I also have the turbosmart wastegate and it works great but the turbo smart boost controller is really lame... It's a bleeder style and boost spikes horribly I had to remove it after one drive, at 7 psi setting it was spiking to 12psi.... GO with something like a hallman pro RX they hold rock solid and are easier to adjust.
                        7speedshop.com
                        • sayed ali
                          • 762
                          :D Thanks!
                          M20B28 Turbo
                          My Build Thread
