why do i keep blowing headgaskets??!
  • The Humjet
    • Jun 2010
    • 528
    #31
    Originally posted by bimmerteck
    Not a ruler, a machinist's straight edge. It's a tool used with feeler guages to check if surfaces are in fact, straight.
    Straight edge from summit racing
    I didn't say there was anything wrong with your method. I've never used that method before. Why would I when I can check it on the mill with a dial indactor customers always get their heads machined regardless. It was the OP that said he didn't check with feeler gauges just a straight edge.
    Anyway OP like I said before get the head pressure tested and resurfaced while its at the machine shop. And get working on your tuning. 13afr is on the lean side you'll wanna be around the 12s. And get some det cans, on high performance car you shouldn't be hearing it by ear. If your hearing it while your driving then that certainly explains your original question.
    Also start working on the timing maps. And post it on here or even e30tech so the more experienced members such as nando can review it for you and explain where you went right and wrong. This all part of the fun of turboing your m20. Learning and gaining experience for future projects.
    • dmjensen
      • Jan 2011
      • 805
      #32
      the head is warped over the last cylinder where it keeps pushing the gasket.
      i could fit a .006" feeler gauge under it and a .007 would fit in one spot...
      so im going to get it resurfaced and pressure tested this week
      • dmjensen
        • Jan 2011
        • 805
        #33
        alright i just got my head back yesterday (looks awesome :up:) but now me and my dad are having a dispute over whether or not we're torquing down the bolts right.
        we used the 30ftlb wait 5 min, 40ftlb wait five, up to 60ftlb
        but other places say 22ftlbs then 90 degrees and then another 90 degrees or something like that.
        what is the right way to torque metric blue Allen bolts?
        • The Humjet
          • Jun 2010
          • 528
          #34
          I would set the final torque at 70ft-lbs. If your threads can handle it.
          Your head has been on and off the block a few times now so that's one of my concerns.
          Try and do as much prep as possible to get the bolt holes clean. I usually run a tap down the threads and clean it with brake clean and an air gun. And then I just lubricate the bolts with a bit oil. Were you running washers last time you bolted up the MB bolts?
          Looks like your getting back on track now. Let's hope that the freshly resurfaced head can solve your problem.
          • dmjensen
            • Jan 2011
            • 805
            #35
            yup, i did reuse the washers before.
            i think im just going to have to fork out the cash for arp studs. I just want to do it right and do it once and be done haha
            • The Humjet
              • Jun 2010
              • 528
              #36
              I can't rate arp head studs anymore highly. We use them heaps with the engines we build and they're certainly a stout bit of kit. You also torque the arp studs more than you would with standard bolts.
              An Ls1 motor for example is notorious for stripping threads out when tensioning up heads with standard bolts, due it having a weaker aluminum block. With the arp studs or bolts you rarely face that issue of stripping threads.
              • dmjensen
                • Jan 2011
                • 805
                #37
                Yeah i ordered them last night. Ie sugests 60ftlbs, should i go more or will that be good?
                • dmjensen
                  • Jan 2011
                  • 805
                  #38
                  Also i forgot to mention but we have no way of getting 93octane in dubuque so the highest we have is 92 WITH ethonal. Otherwise i think we have 91 without ethonal.
                  So i know i was probally way off on afr now since i was running lower octane gas with ethonal. Should i try to fatten it up to mid 11s on 91w/o ethn or will 92 w/ ethn be okay?
                  • Hey_You
                    • Nov 2009
                    • 963
                    #39
                    Another way to clean out your bolt holes is to fill them up with brake clean, let them sit for awhile (hour or 2), and take a q-tip to them. Then follow up with a bunch more brake clean and compressed air or q-tips if they are really dirty. Failure to do so could result in a cracked block around the holes.
                    85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
                    • The Humjet
                      • Jun 2010
                      • 528
                      #40
                      Are you talking about the arps studs or MB bolts?
                      ARP will supply torque specs paper in the box. My guess it would say to torque to 70ft-lbs with arp moly. They usually specify to torque it down 10ft-lbs more than standard.
                      • dmjensen
                        • Jan 2011
                        • 805
                        #41
                        yeah i ordered arps from IE.
                        but they haven't shown up yet so now i get to wait.
