Budget Goals??
    Budget Goals??
    I am looking to build a 250whp m20 turbo motor.
    Main thing for me is for it to be reliable and have a quick spool as this car is being raced.
    Looks Like a I can go with a TCD Manifold and a small T3 turbo.
    One thing that i have no idea on is engine management
    what would be the best setup for keeping this thing from blowing up.
    Also forgot to mention, i am currently running Miller maf conversion, would the War chip at this point be my best bet?
    Also what turbo would you recommend for low lag and my power goals?
    AutoCross Photos!!https://picasaweb.google.com/eugenes18t
    miller war chip is fine for your hp goal and since you have the maf..
    hx35 will do the job perfectly
    good luck,
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
      Hmm so a hx35 and a tcd manifold or manifold adapters, and besides that i guess i would need injectors, piping waste gate, bov, IC and and a frsh head gasket and bolts
        tcd logs needs a on-center turbine housing.
          id say the adapters would flow better then the tdc manifolds. and would give better spool in return.
            Tcd manifolds are too expensive for what they are. An adapter is one option or if you want to go really cheap then a notched 324td manifold could work. You could also run a late 80's volvo garret t3. They spool up really quick. And could be found at a pick n pull wrecker for cheap.
            250hp isn't such a big power goal so that along with your Miller Maf and w.a.r chip should tie in well together and give you that extra kick your after.
              I would say that manifold adapters are better than TCD manifold..
              30lbs injectors will work good with the war chip and they are enough to take you to 250 hp
              better to run a wasgated turbocharger rather than spend $$ on external wastegate
              Oh, don't forget to O-ring your block!
              M20B28 Turbo
              My Build Thread
                hx35 is overkill. I second the volvo turbo... I ran one on my last build and it should support that kind of power. Note that the early 80's turbos are larger than the later models... mine was the early. My suggestion: 666 turbo adapter plus the volvo turbo - it should be reasonably cheap, reliable, and easy to install. Run whatever engine management you feel most comfortable with. I went with megasquirt which is overkill, but fun to play with and can support a lot more power down the road.
                Next to an HX-35
                Hint: it's for sale...
                1997 540i/6 - stock
                1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
                1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
                  Hmm that seems like some nice options
                  now to just decide if i want to turbo the car and have to trailer it to all the races or to go with s50 swap and keep the car street legal.
                    TCD manifold is also a T4 flange. Take a look at the condor speed shop build. Pretty much exactly what you want to do. I'll be doing the same thing next month on my 316i
                    www.gecoils.com
                      Turbo it :)
                      M20B28 Turbo
                      My Build Thread
                        Just because you have a turbo doesn't mean it can't be drivable on the street...
                        Project M42 Turbo
                          ^^Very true.
                          But if this is your dd then I'd buy a cheap shitter to drive around in while you car is off the road and ironing out the bumps which you'll have to do with any project car.
