hi there guys.
i was looking into turbos the other day.
and it dawned on me i wasnt sure what turbo i should run.
i want to stay away from the common t3t4 to4e that people here run on everything.
my thoughts were to go with a gt35 .63a/r turbine and about a .70a/r compressor.
the other option was a td06 20g t3 flanged.
the motor will be m20b25, mls hg, arp stud kit, balanced internals, lighten flywheel, spec stage 3 clutch, mild cam, turbo adapter, fmic, 2.5" cooler piping, 3" exhuast, 38mm gate, boost kept to 12psi max, getrag260, 4.1 diff eventually, and not sure yet if ill go blow through miller maf or standalone with map.
im not all that familiar with some of the turbo part numbers you seem to use.
im familiar with the garret type range. t25, gt2871rs gt30, gtx3078rs, gt35, ect ect
also familiar with the td0 range. td04h, td05 8g,16g,20g,22g td06 16g,20g ect ect ect.
if you could compair anything to those that would be great. it works easier in my head to compair it to what i know.
thanks, leigh
thanks, leigh
