M20 2.9 can i supercharge.
    I have a 2.9 stroker 10.2:1 compression 272 schrick cam, with mls HG.
    I am looking at a supercharger kit that is made for a m20 that claims 250WRHP
    on a stock 325i. and i think it will make my stroker thrash.
    Is my high compression going to be a real issue.
    I know turbo is more efficient and cheaper but i don't want to turbo. and i have heard SC are safer.
    329i
    No way dude. You haz m20 no way jose
        run e85. Problem solved
          I run 98 and it's my dd
          329i
            Turbo is cheaper?? I don't think so...
            with engine like you have + turbo + e85 + tuning = BIG WIN :)
            M20B28 Turbo
            My Build Thread
            http://www.r3vlimited.com/board/showthread.php?t=255839
              i want to SC its easier because i have no AC and it will slot right in there.
              Unlike a turbo where my car is RHD so i have all the steering components in the way, and the heat that a turbo immits.
              329i
                Ummm, superchargers get hot as fuck too. Just sayin. But do it! Blow that biatch!
                85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
                  In for your RHD SC build thread.
                    98 RON is roughly the same as 93 here. It's nothing special.
                    2002 BMW M3 Alpinweiß/Black
                    1999 323i GTS2 Alpinweiß
                    1995 M3 Dakargelb/Black
                    - S50B32/S6S420G/3.91
                    1990 325is Brilliantrot/Tan
                    1989 M3 Alpinweiß/Black
                      so can i run low boost with 10.2:1 with megasquirt.
                      329i
                        I supercharged my stock M20 2.5L at 10PSI.
                        For a 2.9 stroker I would use the M90 SC instead of the M62, I used th e M62 for my engine which is smaller
                        I would run max boost 5PSI - 10.2:1 Compression on you stroker.
                        Denny
                        ___________
                        1990 BMW red 325IC M30B35 all stock Girlfriends ride
                        1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
                        Blogs:
                        http://bmw325e30.blogspot.com/ (restoration)
                        http://bmw325e30turbo.blogspot.com (Twincharge M20)
                        http://bmw325e30m62b44.blogspot.ca/
                          thanks for the advice.
                          How did you stock 325 go on 10 psi.
                          329i
                            its now on 12 PSI with only 16 degree timing at WOT. Only way to describe it ...it accelerates like if I have a V8 under the hood. Lots of low end power except I get a great mid range and some high end too. ITs a beast right now
                            Its exactly what the E30 needed... now I will prepare for the turbo side (twincharge)
                            on your setup I would use the M90 (the one off the thunderbird) and run it at max 5PSI with a good amount of timing and the M50 crank pulley I have one if you need.
                            Denny
                            ___________
                            Blogs:
