So back story: i have a m20 turbo. Crankcase vented to atmosphere.
I start my car its fine. Let it run for a min or two then lots of smoke. Let it run for 10 min and the smokes gone and doesnt come back. Doesnt smell like coolant looks like burning oil. I thought i had blown an oil seal on the turbo so i swapped in another. Nope. Checked the plugs and they looked ok, no signs of oil and it idles and runs fine. I drained and measured my oil. I had 4.5l in it still (mind you i havent done much driving because of this). I was driving this car completely problem free this literally seemed to happen overnight. Any thoughts? Valve seals? Rings? Possible issue with the oil drain line? Also this is a turbo ix not sure if the oil pan configuration comes into play for a possible oil drain line issue. Thanks for any assistance.
