I was wondering how you guys run your IAC when you have intercooler piping and a coupling up to the throttle body? Since the throttle plate is closed, all I could think of is somehow throwing the stock IAC into the piping to idle like normal, but half the pictures ive seen of boosted m20s do not even have an iac. Do you need it? If so, how do you keep it so it doesnt shoot out while there is positive pressure in the intercooler piping?
Also, I was wondering about the brake booster vacuum lines. These lines come into the stock intake bellows, (If the IAC Is deleted, would you just plug it?) if the iac remains, do you just somehow fit it into ic piping? Same question aswell, how do you keep it connected to widthstand boost pressure?
Thanks
Thanks
