Piecing together a turbo build
  • ser1992
    • Feb 2013
    • 482
    Hello everyone, I'm a long time lurker with a bunch of friends who have built e30's, now im taking the plunge and am looking for a little advice.
    GOAL: 350-400hp
    What I have:
    spare M20
    HX35 (7 blade 12cm)
    s50 rods (these will work, right?)
    ETA crank (s50 rods will work with this crank, right?)
    New OEM head gasket
    ARP Head Studs
    Planning to buy (open to advice):
    O-ring the block
    Intercooler/piping etc
    Help please!:
    Tuning/management (MSpnp?)
    What injector size should I buy?
    Any thoughts and ideas are welcome and thanks again for the advice. I'm looking forward to learning a lot from you guys! :D
    (I have used the search but could not find much on the ETA crank w/ s50 rods)
  • sayed ali
    • 762
    60lb injectors would be your best choice IMO, however, even 42lb can do well for ~350whp
    O-ringed block = YES
    MSpnp = WIN
    and about the rods:
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
    • ser1992
      • Feb 2013
      • 482
      Great thanks!
      and just to clarify, a set of stock m20 pistons, s50 rods and an Eta crank would all be compatible and would be a 2.7 right?
      • travish325
        • Jun 2012
        • 1151
        Originally posted by ser1992
        Great thanks!
        S50 rods are 135mm the same as m20 so with an eta crank yes youll be at a 2.7. If your gonna spend money on s50 rods I wouldnt cause they are the same size as your stock ones (unless it was stock an eta) and stock will hold up fine well into 500hp.
        Already said mspnp yes
        oring yes
        60lb injectors yes
        goetze gasket for sure
        easily 400hp.
        I made 500hp on a stock 2.5 motor with ms and 60s and no oring just fine(but If you can oring it do it, it can only help). You will probably be right around 20psi too
        • ser1992
          • Feb 2013
          • 482
          i got the rods for about $50 and were weight matched already. I heard they were a little stronger and lighter, so what the heck, right.
          60lb injectors, would you just suggest the Bosch style 3 ones?
          • ser1992
            • Feb 2013
            • 482
            would i need to weld the water channels on the head? i hope not because im new to Seattle and dont know of a shop i would trust. if anyone has one thats already done and wants to give it to me for free ill take it. just kidding, but i would like more thoughts on this. thanks!
            • ser1992
              • Feb 2013
              • 482
              and is this the right head gasket?! $37!?
              • travish325
                • Jun 2012
                • 1151
                Cool thats ok then
                No doesnt have to be welded but it helps a lot giving more surface area bolted down
                60lb seimens injectors from injectorconnection.com
                And yes thats the right gasket. Cheaper on pelican parts I think
                And do some research on turbo builds over on e30tech theres a lot of turbo info there
                Ohhhhh annnd apr head studs fa sho
                • ser1992
                  • Feb 2013
                  • 482
                  ya I want to pick up the ARP studs from IE. I cant believe how cheap some parts are for these cars!
                  Im on e30tech also but my damn account is still waiting on authorization or something...
                  • travish325
                    • Jun 2012
                    • 1151
                    You can still troll over there.
                    • ser1992
                      • Feb 2013
                      • 482
                      is this the site you meant? http://www.fuelinjectorconnection.com/
                      • ser1992
                        • Feb 2013
                        • 482
                        i kill hours over there...
                        • travish325
                          • Jun 2012
                          • 1151
                          Yep thats the site. Good deals there
                          • ser1992
                            • Feb 2013
                            • 482
                            awesome thanks for the info
                            now off to find a manifold...
                            • travish325
                              • Jun 2012
                              • 1151
                              I know a guy selling a revshift manifold
