Fresh Turbo engine advice
  • sayed ali
    • 762
    Hello,
    I've recently rebuild my m20 motor with all new internals + m52 crank, my question is how long should I let the engine idle for the first start up?
    I've heard some people saying that I have to start it for 3-4 days about 2 hours per day, is that true?
    Thanks in advance..
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
  • beefjurky69
    • 613
    I let mine idle for 20 min than change the oil. Go out and drive it kinda hard with alot of decel to set those rings.
    Build Thread
    http://www.e30tech.com/forum/showthread.php?t=84988
    "When In Doubt Boost It Out"
    ~89 325I Turbo 11.90 @ 121~
    ~ 420whp/420tq~
    15psi
    ~Paul Burke Built 2.8L Stroked M20
    ~666 Divided Mani T3
    ~6262 T3 Turbo
    ~O'ringed Block SS
    ~Custom Fuel System
    ~3'' Turbo Back
    ~50mm Tial Bov
    ~Dual Tial 38 Gates
    • sayed ali
      • 762
      Hmmm, sounds a little hurry, anyway thank you and good luck
      M20B28 Turbo
      My Build Thread
      • whodwho
        • Jun 2008
        • 1547
        I don't see the need for idling for break in, my opinion is only idling it long enough to make sure you have oil pressure and you don't have leaks and then driving it to load the rings when the critical part of the ring seating happens. And if you have a new cam you don't want to idle it until after the cam break in procedure.
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        • 93supercoupe
          • Oct 2012
          • 84
          x2
          Heres my break in......
          idle it, check for leaks, get it upto operating temp, change the oil and strap it to a dyno and let it rip
          • FLG
            • Sep 2011
            • 3165
            As stated, get it running, check for leaks, change oil and go out and drive the piss out of it letting the engine do a lot of the breaking (decell). Id honestly just check for leaks and like supercoupe said go straight to dyno though.
            -Build http://www.r3vlimited.com/board/showthread.php?t=295277
            • jules325i
              • Jul 2011
              • 353
              I was under the impression that idling a new engine glazes the Bores and the piston rings dont bed in properly and that you should set the rpm to around 1500, and when driving you should alter the engine speed plus avoid extended periods of high engine speeds.
              329i
              • JCarp90
                • Feb 2011
                • 1759
                Listen to FLG. Fire it up, check for leaks and then beat the shit out of it. 3rd gear pull, then decel in the same gear.
                • chondamx
                  • 247
                  This is how I always broke in my new motocross bikes and fresh rebuilds. I ran them thirty minutes, changed oil, and rode them at race pace while being conscientious of varying RPMs. It's an age old debate, but I firmly believe light breaks-in result in glazing...I've never had a bike smoke, even those that were ran long enough to toast crank bearings without a top end build.
                  '91 318is M52 Turbo (in pieces)
                  • Kozworth
                    • May 2011
                    • 1339
                    I dont understand this. I did the same exact thing to my previous m20. Rebuilt, oringed block, and blew the headgasket on one of the first pulls. Ive always heard things like "take er easy on the first 500 miles" or whatnot after an engine rebuild. I am disagreeing with you guys but I am just wondering how these rumors are actually fiction.
                    • FLG
                      • Sep 2011
                      • 3165
                      Something was not done correctly or there was some kind of defect possibly. When I broke in my 440 for my charger we brought the engine to the dyno after 20 min of varying rpm to break in the cam, changed oil and beat the shit out of it. You could tell when things were seated, no more blow by and hp/torque increased as the pulls went on until it settled.
                      Sent from my SCH-I545 using Tapatalk 2
                      • Jeff Schaadt
                        • Jul 2013
                        • 141
                        Bought a brand new 2007 Mini Cooper S, drove from Dallas to Houston that Friday nite....did a 2 day National Tour (AutoX)... Put 50,000 miles on her, multiple trips across the country to attend an AutoX.... Never missed a beat.
                        WMMFT Racing/Condor SpeedShop/BimmerHeads
                        • andrewm
                          • 456
                          So....
                          there's a few varaibles. That "idle and rev" period is usually for motors with new cams, because the cams need to cycle.
                          I'm a HUGE fan of beating in a motor with runs. The few I've built...
                          Start up, idle/rev 5 minutes. Change oil.
                          Cam break in. Change oil.
                          Then I beat the living hell out of it. I took it to a backroad that was 65mph in a light traffic environment and went through second and third gear pulls for an hour or so. The rings will set pretty quickly. Change oil.
                          Then its erally just normal heat cycles, but you NEED the heat to set those rings. If something goes wrong (HG, bearing failure, etc) - something else was wrong.
                          1987 Delphin 325e Sedan - Natalie
                          1990 325i 24v
                          1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
