Whats up guys, i just got done with my m20 build and am having some issues that no matter what i do, i cant get rid of.
The setup
1988 325 with super ETA
super ETA stock block, oringed and head studded
I head with shrick cam, slight port job, port matched I intake manifold and I TB
61mm inducer turbo, ebay probably
real tial wastegate, tial knock off BOV
DIYautotune DIY PNP megasquirt kit
60lb bosch, 255 walboro fuel pump, both brand new
innovative LC1 with brand new sensor
stock ignition with NGK bpr7es and MSD coil
running on spring pressure (14lbs)
Ok so heres the deal. No matter what, there is a random lean spot when WOT in boost. Wether its 3200 or 5200, it will always spike lean and break up. I can rarely get threw a gear under full throttle. The car is real choppy at cruising speeds even with a 13.5AFR. My logs are telling me its going lean, but with the partial throttle choppy-ness, im leaning towards an ignition break up.
i took some screen shots of my logs and maps. Let me know if i can provide any more info. The car is super fast until it breaks up. Its not showing any signs of detonation on the plugs and sounds great (until it breaks up)
The setup
