Only on start and after revving it smokes a bit
My low milage turbo Prep
What color?1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
I'm at 18psi on metric blues. A resused set at that. Over 20k miles clocked.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
You could do what I did if you wanna make a quick spooling 250 on the cheaper side of things....It's 24lb injectors, a volvo turbo & intercooler, and a retuned stock chip. It took a little fiddling with the afm but it's running great. Stock hg and bolts, although I will probably switch to ARPs as soon as I can.
'73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]Comment
PmYou could do what I did if you wanna make a quick spooling 250 on the cheaper side of things....It's 24lb injectors, a volvo turbo & intercooler, and a retuned stock chip. It took a little fiddling with the afm but it's running great. Stock hg and bolts, although I will probably switch to ARPs as soon as I can.
Me deatailsComment
