cheap turbo
  • tomgt325
    • Jan 2006
    • 472
    cheap turbo
    i am able to buy a 16g turbo for $100. do u guys think it'd work? is it even worth the trouble?
    thomas
  • The Fast One!
    • Jul 2005
    • 856
    maybe a 20g but correct me if I'm wrong but I'm pretty sure the 16g is even smaller and it's airflow would not be good enough for a 2.5 motor.
    Mike Fritz
    • tomgt325
      • Jan 2006
      • 472
      they're upgrades for dsms (2.0 ltr), so hopefully it'll flow enough. i want it to spool relatively quick anyway
      • The Fast One!
        • Jul 2005
        • 856
        that's right, I had my turbo's mixed up the 16g, is the evo III turbo.
        I think it is a T28. the flow rate should be fine for a M20. should be able to make about 300-350 whp with that turbo, which for an m20 to get to 300whp is a lot of work and is plenty fast enough.
        just make sure to boost 8psi or more, the flow chart look like that makes its power from about 8psi to 19psi.
        Mike Fritz
        • tomgt325
          • Jan 2006
          • 472
          thats enough for me!!
          • PJ
            • Jul 2005
            • 71
            omg.
            "The turbo from a truck is not built for much horsepower on a gasoline engine."
            • The Fast One!
              • Jul 2005
              • 856
              Originally posted by PJ
              omg.
              O RLY?
              Mike Fritz
              • PeaveyBassist
                • Sep 2004
                • 3511
                1st gen DSM buddy says if youre only gonna run 8psi, a 14b is good enough. 16g is probably a little on the big side. $100 for a MISTSUBISHI 16g is good he says.
                Will
                RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                Welcome e30 (brilliantrot '90 325is) 12/23/06
                DaveCN = Old Man
                My signature picture was taken by ME! Not by anyone else!
                If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                • silversleeper
                  • Mar 2005
                  • 2032
                  do a twin turbo setup!
                  run dual SR20 turbos... get a custom manifold done, and ur set for maximum pimpage!
                  Claus Luthe is my hero.
                  • tomgt325
                    • Jan 2006
                    • 472
                    i just gotta find another 16g....hmmm
                    • tomgt325
                      • Jan 2006
                      • 472
                      bought it today...and no shaft play at all!!!!!
                      apparently only 20ish,000 on it.
                      turbo project has left the ground:D
