Ive had the m30b34 in the e30 for about 5 years now
Its had a hard time and started using oil so its time to come out for a rebuild
Plan for engine:
Get crank ground
new bearings for bottom end
bore and hone block
reuse stock rods
low comp forged pistons
block decked
fully balanced assembly
head skimmed
cam regrind
heavy duty valve springs
billet rockers
rocker stoppers
mls gasket
arp head studs
garrett gtx35r
top mount manifold
custom front facing plenum
80mm universal throttle body
Motor is out of car and ready pulled apart
Will post some pics soon as its getting some mtech1 goodies as well...:)
Plan for engine:
Get crank ground
bore and hone block
reuse stock rods
block decked
head skimmed
cam regrind
billet rockers
rocker stoppers
mls gasket
arp head studs
garrett gtx35r
top mount manifold
