So, here is my thought
I am going to be starting my freshly rebuilt m50nv soon, and it will be on ms3x. I did piston rings and the bottom end bearings. I want to let the rings seat without boost (or does it not matter too much?) because I feel like boost on a fresh motor is not a good idea.
My wastegate spring is set for seven psi, and I am running a blunttech manifold with an external wastegate, I need to keep the turbo on for startup/break in because I have all of the oil passages plumbed for it.
Is there any way to keep the turbo from just spooling a ton? I am trying to figure out if I should just disconnect the charge pipe from the intake but then the turbo would keep spooling, no?
Cliffs, Need turbo on car, don't want boost.
