What hotside housing should I buy?
  • ser1992
    • Feb 2013
    • 482
    I have an hx35 12cm and a full Revshift manifold (non splitpuls). should i look for a non gated non splitpuls housing? if so who makes it and where can i buy it.
    Im looking to make somewhere around 400hp when finished, is a 12 cm enough or should i look for a 14?
  • E30-323ti
    • 328
    IIRC you can get an 'O' or 'N' trim T4 turbine housing ported to suit the HX35 turbine.
    Otherwise, I think Bullseye Power (BEP) are the only ones that do an off the shelf T.Hsg, but are a bit smaller (~8cm) as they were developed for the DSM crowd and come is a variety of inlet & outlet configs.
    292rwhp E30 :D
    • Pootis
      • 636
      12cm will be enough to make 400hp 14 will just be more lag I would stick with the 12
      1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
      COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
      • kamotors
        • Nov 2007
        • 7102
        10cm makes 400hp just fine.
        7speedshop.com
