Need advice m20 turbo build.
  • timmyr77
    • Jun 2012
    • 353
    So I've started to to build my head on my m20 and I have read that for na porting and polishing a head is basically as far as $$/powergain. So is it worth porting and polishing the head if I'm boosting it.
    Plannin to have
    272 camshaft
    Possible heavy duty rocker arms
    IE valve springs
    And stainless steel valves
    Most likely not running more than 18 psi
    (I'm new to turbo set-ups so sorry if this is a stupid noob question)
  • timmyr77
    • Jun 2012
    • 353
    Oh and a 2.7 bottom end
    • ColdAsLife
      • Mar 2013
      • 142
      What is your power goals? At 18 psi depending on your tune your HP can vary from 375 to 450 on that setup. There is recorded accounts of the swedes getting up to 650HP on untouched 885 heads so I personally would stay away from porting the head as its not a bottle neck in what I can assume are your goals are. Currently the least capable piece of your build will be the eta pistons in the 2.7 bottom end which will hold you back before the 885 head will IMHO.
      I'm running a Ireland 272 cam and if I were do it again I would run a Z45 turbo cam from Pure Performance Factory.
      Hope this helps.
      • timmyr77
        • Jun 2012
        • 353
        so porting wont do much hp wise. well once i have the seta pistons ill be good to go, just need to rebuild the head. ill look into the z45 cam. and if i dont pollish and port that will save a good 400-800 bucks.
        any other thoughts on this?
        • Good & Tight
          • Apr 2004
          • 2057
          Don't waste your money on port and polish for a stock bottom end turbo setup.
          Now if you had forged rods and pistons and wanted to run over 25psi then yes port and polish would be worth it along with a good tubular manifold and a cam.
          Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
          ____________________________
          E-mail Panayiotisx2@gmail.com
          Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
          • timmyr77
            • Jun 2012
            • 353
            ok thanks
            • pantelones
              • May 2011
              • 533
              One BIG thing that most people don't realize about a turbo set up is that the cam really needs be custom ground for your set up... Read this....
              See how cam design is different for turbocharged engines compaired to natural aspirated build. Only at www.hotrod.com, the official website for Hot Rod Magazine.
              "In truth, Godbold says 99 percent of Comp Cams' turbo grinds should be custom profiles because "pressure differential can be all over the place. The reason we don't have a lot of catalog turbo cams is because there are not a lot of catalog turbo systems." Every turbo installation is unique."
              A man chooses, a slave obeys... Would you kindly?
              • JTapper
                • Sep 2009
                • 847
                Do the heavy duty rockers, and ARP studs top and bottom, and you should be good to go.
                I ran 20psi on an ebay .63ar T3/T4 turbo and had nothing but fun with it. All stock internals, only upgraded to studs. I had an SETA bottom end with an 885 head, cometic MLS head gasket.
                Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
                • 1owNslo
                  • Apr 2012
                  • 334
                  not trying to steal this thread... but where do you go about getting a custom ground cam? and where do you start in respects to that? do you give them your end HP goals and your set up and they grind you a cam????
                  10 minutes... then we invade China.
                  We'll begin with the small town of General Tso's,
                  And move to the Orange chicken province.
                  • einstein57
                    • Jun 2007
                    • 10780
                    BimmerHeads is a full-service engine builder, engine machine shop, and parts house specializing in Classic BMW vehicles.
                    www.gecoils.com
                    • pantelones
                      • May 2011
                      • 533
                      Did you read?
                      http://www.hotrod.com/pitstop/hrdp_1...s/viewall.html
                      Then read...
                      Then AFTER you have done all your homework, and have your set up compiled you can go about getting something to suit your set up.
                      Any power goal under 300'ish HP is fine with the stock cam. Anything that deals with power goals and PSI over, lets say 15+PSI SHOULD have a custom ground cam. Again, this is at your discretion and knowledge of engine design. My honest opinion is that if you plan to make 350+ WHP out of an m20 you better be doing your homework, and know that cam design is very important. It's right behind having a proper tune.
                      Also, don't quote me on those numbers either. Personally, I would have a custom ground cam even if I was only running 6 PSI...
                      • 1owNslo
                        • Apr 2012
                        • 334
                        +1 thanks!
                        • 1owNslo
                          • Apr 2012
                          • 334
                          ++1 really good read and makes a hell of a lot of sense.
