Boosted m20 2.5 to 2.7 stroker question!?!
  • GUERONASTY
    • Aug 2011
    • 811
    So started my budget build building my first engine build/rebuild to drop in my boosted M20. I have an '86 2.7 M20 block and a '89 2.5 M20 head. Just got everything back from the machine shop and all new maintenance parts arrived. I'm stuck at the moment and need some help. Been reading that I have to either A) Run '88 SETA pistons B) Run "i" pistons shaved 2-3mm C) Custom pistons. My question is is that only for N/A or boost aswell or can I run it like that (or is compression to low)? If it were not to be possible just gonna run my existing M20 "i" block that's in car already with the fresh "i" head nnd use my money to go Megasquirt instead!
  • TheTacoMan
    • Nov 2011
    • 2308
    You can use the stock e pistons with the "i" not the most ideal but it works fin IMO
    • GUERONASTY
      • Aug 2011
      • 811
      Not to convincing lol think I stick to 2.5 bottom end and "i" head
      • Ceeker
        • Sep 2009
        • 2821
        I got the same set up and running 10lbs boost. e 2.7 block with I head. everything is stock motor wise.
        • GUERONASTY
          • Aug 2011
          • 811
          How's that running? What compression does that make? Power?
          • TheTacoMan
            • Nov 2011
            • 2308
            Look up the two kamotors built recently, they are both 85e s and they made good power. Both are very fast.
            • GUERONASTY
              • Aug 2011
              • 811
              Could not find it. Link to share?
              • AbsorbantNut
                Non faccio funzionare questa merda
                • Jun 2010
                • 2491
                For all those people who find it more convenient to bother you with their question rather than to Google it for themselves.
                The top result & the two bullets below it. I believe those are the ones he's talking about
                '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                • GUERONASTY
                  • Aug 2011
                  • 811
                  Still can't figure out weather to run...
                  1) "e" 2.7 block with "i" 2.5 head
                  or
                  2)"i" 2.5 block with "i" 2.5 head
                  ...on boost. What will be ideal for it?
                  • andrewm
                    • 456
                    or
                    that depends on your goals.
                    The E bottom will have lower compression, but more displacement.
                    The I will have higher compression, and be trickier tuning because of that.
                    I'm building an E motor with and I head for boost currently because I'm only an OK tuner. Last time I got really into a car was an MR2 and I BUILT the motor. With forged internals I opted for the stroker motor with higher compression ratio because...torque But with the e30 I'd rather have the displacement and margin for error.
                    1987 Delphin 325e Sedan - Natalie
                    1990 325i 24v
                    1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      or
                      Research. Google. Search.
                      • GUERONASTY
                        • Aug 2011
                        • 811
                        That's all the same thing.
                        • einstein57
                          • Jun 2007
                          • 10780
                          Several people have said its fine. Need a letter from BMW NA too? lol
                          www.gecoils.com
