m50 boost HELP
    m50 boost HELP
    i have m50b25 with mls .140 hg, arp head studs, otis manifold, hx35 turbo, 3inch dp, 60lbs injectors, turbo smart boost controller and trm chip. i have a 44mm mvr tial wg on the manifold. This is what happend...... i had a 2.25 inch exhaust going from the dp to a magnaflow muffler, and a 5.35psi spring (blue spring) in there and the wg would open at 8psi. then one day i went and replaced the exhaust with a full straight 3 inch exhaust no muffler. once i started driving the wg started opening @ 12psi. so i called trm and they said get the smallest spring ( the red one) i replaced it and now it boosts @ 15psi!!!!! i was told maybe the boost controller could be the problem, so i removed it and it didnt do anything. i also switched back to the blue spring wich is 5.85 psi. why am i over boosting????
    all the ports on the wg that arent being used are plugged. PLEASE HELP ME
    Sounds like creep...
      Blow some pressure through your Wastegate vacuum lines. Could be clogged with gunk/oil.
      1991 325iS turbo
        i doubt it everything is new on the car, barely has 100 miles on build
          I said that too.
          After deleting the MBC, changing the waste-gate spring twice(annoying location on my car), it was just the lines..
          Anywho, check lines whether clogged or pinched.
          Is it pegging at 15psi or are you taking it that far and stopping out of fear? Your diaphragm could of ruptured? I have that same gate.
          1991 325iS turbo
            I said that too.
            thats the highest ive been, then let off out of fear, lines arent pinched- they have enough room. what should i do?
              Check to see if they are clogged. Blow-by crap can get into the lines over time.
              1991 325iS turbo
                Wait wtf. Leave your top air port on the waste gate OPEN. Plug the side air ports that you aren't using.
                1991 325iS turbo
                  yea the 2 top ones are open
                    will do ill try and let you know how it turns out
                      same thing nothing changed....
                        check the diaphragm in the tial. Check it all holds pressure and doesn't leak.
                        fake tial are rife....
                        89 M50B28 turbo
                        LINKY
                          Did you add the silencer and tip to the exhaust and did that help?
                          Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                          ____________________________
                          E-mail Panayiotisx2@gmail.com
                          Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                            Otis got it, you need something in the exhaust line, we have had a bunch of customers with the same issue, added a muffler and they are all set and holding steady
