Turbo manifold
  • CLASH
    • Nov 2013
    • 39
    Turbo manifold
    Have any one here used this turbo manifold from CX racing?
    is it good enough for for 8-12 psi ?
    thanks
  • LowR3V'in
    • 4209
    I had one but it cracked at the turbo flange. Little hairline crack.
    • sayed ali
      • 762
      I don't recommend that ..
      M20B28 Turbo
      My Build Thread
      http://www.r3vlimited.com/board/showthread.php?t=255839
      • jaywood
        • Jul 2010
        • 4528
        It's a well designed manifold that uses sub-par materials. Reinforce it and you'll be fine.
        • CLASH
          • Nov 2013
          • 39
          Does it has any issue for fitment?
          Thanks
          • LowR3V'in
            • 4209
            Cut the flange in half.
            In the old days people would drill out the holes but just
            cut the flange in half and it will give you play.
            • CLASH
              • Nov 2013
              • 39
              do you have any picture for your project? just want to see how you did it
              Thanks
              • TheTacoMan
                • Nov 2011
                • 2308
                I did this as well as drilling the holes out a bit, manifold holds up fine otherwise.
