Okay, I thought about it for a few months and I want to turbo my m20. I am going to research and slowly build. I am in no rush whatsoever. I am still learning about this whole process. I want to try to be under $4000 for the build
My car is my DD so I was thinking about buying a stock m20 engine,installing as much of the parts as I can, and then taking off a week or so (as much time as needed) and swap the engines..
As far as the internals of the m20 go, I understand replacing the head studs with ARPs and a new head gasket and injectors should be fine with 12 pounds of boost. (True?)
My question is there any order in what I should buy for the turbo build after I replace the studs and head gasket. Turbo manifold? Injectors? Piping?
Any advice or tips are welcomed. Thanks!
