m20 turbo questions
  • dougie30
    • Apr 2012
    • 1708
    m20 turbo questions
    first of all yes i have done alot of searching and build thread reading.
    im looking to turbo my m20 and i have a good idea on what im looking for i just have a few questions. im looking for around 300hp and i plan on building the head with hd rockers and the duel pattern bimmer heads cam. I also will be using megga squirt but im not sure on the size of the turbo.
    Im not looking to spend a billion dollars and yes i know it wont be too reliable but i have been looking at the cx racing turbos. they sell the gt35 with their kit but i have read that it spools pretty late and it a bit to big, so i was thinking maybe a gt30/28? not sure if they would be to small or not?
    for the manifold i have narrowed my choices to these two
    http://www.amazon.com/gp/aw/d/B007BS...&robot_redir=1
    I really like the adaptor but im not sure about how it will flow and if a 44mm waste gate will be to big?
    and the full manifold im not sure on the quality and fitment. im just seeing if anyone has used either of these or have any input.
    thanks,
    Sent from my SPH-L710 using Tapatalk
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
  • Nutzy
    • Sep 2011
    • 102
    Having seen (and tried to fit) the option 1 manifold in person, I would take the adapter! 44mm WG is fine.
    HX35 is a cheap and plentiful turbo for you to use. Forum members often have these up for sale. The "GT" Chinese turbo's you are looking at are a poor clone of the Garrett dual BB GT's. Don't expect them to perform as well or spool as well.
    The saying that goes "The poor man pays twice" can very well apply when it comes to turbo gear.
    89 M50B28 turbo
    LINKY
    • paulyfresh
      • Feb 2007
      • 2
      with the obx shown in ebay add what else aside turbo is needed for a full pieced together kit? intercooler EMS and ....? id like to boost also but also "boostin on a budget" looking for a good kit that id pay once for done right...
      whats reccomended set up's? im looking at kamotors
      • dougie30
        • Apr 2012
        • 1708
        thank you for the input nutzy i apreciate the input, and you dont think the hx35 is to big for the m20?
        • TheTacoMan
          • Nov 2011
          • 2308
          Definitely too big, I would go with 20g Sized seems to work well.
          • dougie30
            • Apr 2012
            • 1708
            what do you mean by 20g?
            • Nutzy
              • Sep 2011
              • 102
              You're kidding me right? HX35 would have to be the most common M20 turbo I've seen used!
              I used an S256, bigger than the HX35, on a stock B27. Full boost at 2800.
              89 M50B28 turbo
              LINKY
              • sayed ali
                • 762
                +1
                HX35 is a common choice on m20, at least from my little experience :p
                M20B28 Turbo
                My Build Thread
                http://www.r3vlimited.com/board/showthread.php?t=255839
                • blasphemy101
                  • Apr 2012
                  • 170
                  The HX35 is commonly used because it's close to the right size for an M20, it's cheap, and it's durable. Most M20 turbo guys (like myself) just want boost at a cheap price. The HX35 definitely accomplishes that.
                  There are certainly better options but they either cost more or don't last as long. The HX35 is a good/easy choice, but not the BEST choice. You have to keep in mind a T3-flanged 20g is either an Ebay turbo or costs 3x as much as an HX35.
                  The Great Big M20 Timing Belt DIY
                  Some good information I've found online (no affiliation):
                  Turbo Tech (Garrett)
                  Four-cycle information and cam properties for beginners (ISKY Racing Cams)
                  • dougie30
                    • Apr 2012
                    • 1708
                    what im worried about is when it will start boosting, i have the obx adaptor and im sure it dosnt flow to great so i dont know if it would spool the hx35 soon enough as a high flow manifold
                    • Nutzy
                      • Sep 2011
                      • 102
                      That adapter looks about as good as it gets. Plenty of dudes have been making whopper power with stock manifolds and the original and OBX adapter. Having seen the ebay full manifold, I was less than impressed with its quality, port angles, and wall thickness. I sent mine back and got a refund. Big POS!
                      The Kinugawa TD06 20G would be a reasonable choice for your goals. 58mm turbine exducer so lets the M20 breath easy. $900
                      The GT3076 has a smaller turbine and BB centre and will spool harder. Russian Blue (IIRC) used one of these and reported he thought it was too small, too hard to modulate. But IF you are truly only seeking around 300 crank HP it'll be OK. It does cost around $1500 though....
                      89 M50B28 turbo
                      LINKY
                      • ak-
                        • 12422
                        One of the 18g Kinugawa turbo's have the exact same iducer/exducer specs on both compressor/turbine wheels as a gt3076R.
                        This was going to be my choice of turbo until I just rebuilt mine instead. My goals were higher than yours too.
                        1991 325iS turbo
                        • dougie30
                          • Apr 2012
                          • 1708
                          that is a nice looking turbo, the same type kamotors uses in his kit i belive. its just a bit to pricy for what im looking for.
                          this is my first turbo build and im learning how to tune. i dont belive its a good ide to strap a 900$ turbo on if im more than likely going to break something.
                          just looking for a some cheaper options
                          • speedracer 2002
                            • Dec 2013
                            • 359
                            what are you planning on breaking? If you want to turbo an m20 successfully the right way once then you're going to need to spend the money or you'll have to do everything multiple times. M20 motors are fairly strong when they're not pushed to their limits and maintain properly.
                            I daily drove my M20 6262 E85 turbo e30 for over a year on 13lbs make about 315 to the wheels with no issues. I have since went wasted spark and turned it up to 19-20lbs making over 420 to the wheels. Take in mine my M20 is just a freshened up 885 head, headstuds, headgasket. Nothing else.
                            • dougie30
                              • Apr 2012
                              • 1708
                              i dont plan on breaking anything, im just saying im doing a budget build and its my first time so id like to start will some cheap parts anf work my way up once its tuned properyl anf i work out the bugs
