Hello R3v - meet Audrey.
Last weekend I traded my 1991 325ix for a Turbo 1987 325is - here are some pictures to start.
I don't know a ton about the setup at this point, and I am totally new to turbos. I have been doing lots of research in order to help me out.
What I do know...
1987 325is
Super clean body, rust free.
170k on the clock
2.7 block and 885 head installed at 163k
524td crank
shrick 272 cam
running about 9 psi
42lb injectors (seems high? I'm definitely running real rich)
Haltech Engine Management (e6x - having trouble getting logged into it from my laptop)
The knotchiest, and shortest short throw shifter on gods green earth
eibach springs
bilstein shocks
ix wheels with 15mm spacers (took them off the ix in the trade)
The car had about 8 quarts of oil in it and no spark when I took it. I changed the oil, replaced the spark plugs with some ngk bpr7es's and sure enough it started - shot out a ton of smoke for a bit, and still seems to be smoking slightly (currently suspecting valves?).
Anyway, once the massive smoke subsided I was able to drive it. Lumpy idle, but would smooth at a bit once warm - stayed VERY low though. The car pulled amazingly at first, very quick car. After day 3 I was gaining confidence in it and it seemed to be getting better every time I started it. Took it out for a drive and then when I stop my idle must have been at 2500-3000 rpms! crazy high!
Seems to be an odd icv setup that is no longer functioning - I'll add some pictures soon enough to see if anyone knows anything about it. It essentially takes the throttle body opening that would normally hold the crankcase breather hose and routes it to this device (icv) that allows it to send air to the ICV port in the Throttle body - if that makes any sense. Pictures will come. Appears a large set screw came out while I was driving that now allows the ICV port to be open to outside air. Anyway, that is fixed.. temporarily.
My idle seems to still be quite lumpy though, and I am now experience some bogging/hesitation both with and without boost. I haven't gotten a chance to look into it but will today after work.
From what I have read the 42lb injectors with only 9lb boost seems to be an odd combo? I am definitely running rich and I suspect it has something to do with my now bogging.
Anyway, figured I'd share the new car and things I have ran into so far. Any advice is always welcome and I'm sure I'll begin to be more active in the forced induction section.
Cheers,
Doug
What I do know...
1987 325is
170k on the clock
524td crank
shrick 272 cam
running about 9 psi
eibach springs
bilstein shocks
Cheers,
Doug
