how much can the stock fuel line support??
  • dustyperez
    • Feb 2012
    • 390
    Can anyone tell me how much hp the stock lines can support. I dont mean the pump, i already have a 255lph which i know wont support it so i plan on upgrading to a 340 from aeromotive. Will the 5/16 line support 600 hp? Thanks.
  • bobross
    • Jul 2005
    • 753
    Originally posted by dustyperez
    Can anyone tell me how much hp the stock lines can support. I dont mean the pump, i already have a 255lph. Will the 5/16 line support 600 hp? Thanks.
    Stock fuel lines will handle anything a 255 can produce. 255 though, will come up well short of 600
    -Greg
    90 325isT - 12.2 @ 120ish - Dyno Results
    b18c5 EG Coupέ - 13.5 @ 100ish - Dyno Results
    • dustyperez
      • Feb 2012
      • 390
      Ok so if I throw in a 340 from aeromotive will I be good or those lines need to be bigger?
      • bobross
        • Jul 2005
        • 753
        the aeromotive 340 should defiantly make it past 600. I cant think of anyone yet who has fit one in a stock e30 tank.
        Stock e30 hardlines have made over 600
        -Greg
        • dustyperez
          • Feb 2012
          • 390
          I saw that they make a stealth series that go in tank.
          • dunebuggyjay
            • Nov 2011
            • 257
            Yea I was looking at those too. I think it should fit like the 255, but I have not done it yet. I am building a turbo s52 (with gt35r)
            Anyone out there use one yet?
            Jay
            • Dphraner
              • Dec 2012
              • 41
              hey, im using a aeromotive 340 in my m52 turbo car and it just made 550hp on the dyno. mine is a 318is if that matters on the size of the fuel line. im using injector dynamics 1000cc injectors and the tuner said I had plenty of fuel left to go for more. but I was having boost creep problems so I had to stop. anyway the pump fit fine but I had to trim the bottom of the hanger a little and use a hose clamp to mount it. also you should use a relay from the battery with 10 gauge wire so you don't overload the stock wiring.
              • dustyperez
                • Feb 2012
                • 390
                right on thats what i like to hear, any details on that wiring?
                • Dphraner
                  • Dec 2012
                  • 41
                  Just use a heavy duty relay and use the stock fuel pump wire as the trigger wire to turn the relay on. also its a good idea to put a inline fuse between the bat. and relay. Its really simple, you should be able to google it and find some good diagrams. I mounted mine behind the rear fender liner right above the battery to keep it out of sight and to keep the wiring short as possible.
