Anyone rocking all 3? Did a search and didn't come up with much. If you are, please post your recipe.
325ix + turbo + A/C?
Tags: None
Although I don't have AWD, I am running both. I ran an intercooler behind the kidney grille and the piping behind the lights. You are going to have to take off the plastic shields behind the lights to make room. It's a tight fit, but it will work. You will have to run without a condenser fan, though. On the highway, my A/C works well. Around town, not so much. I'm running a clutch fan with the shroud with my setup, if that matters.1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
2012 Passat TDI - DD Duty
2008 GMC Yukon XL Denali - Kiddie hauler/grocery getterComment
I'm not doing it to my IX, but the manifold I'm using will do what you're asking.
https://www.facebook.com/spiessfabrication/ built my twin scroll that's going in now. It'll take an oil filter relocation kit to make it work, but that's a handy thing to do regardless.
FML, I'm necroposting. Le sigh.Whatever
88ix coupe, 89seta turbo sedanComment
