Pushing a M20 to ~450whp !
  • sayed ali
    • 762
    Hello,
    I'm looking forward to get your opinions / experiences
    Specs:
    M20B25 / slightly ported head
    84mm crank
    O-ringed block
    ARP head studs (still waiting for them)
    Custom turbo mani
    Custom intake mani
    80lbs Injectors
    Bosch 044
    Haltech ECU
    Goal : ~ 450 whp - Pump gas
    My question is that currently I've a GT35 T70 (copy) turbo (similar to this)
    with A/R .63 & I'm planning to put on a turbo cam (vac motorsport) .. Will this turbo + cam can reach that power levels @ reasonable boost ?
    Or
    Should I buy another decent turbo (thinking of Precision sc 6266) + stock cam .. ?
    Thanks in advance,
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
  • beefjurky69
    • 613
    I run a 6262 t3 with .82 A/R I made 450hp on old motor 17 psi and new motor made 420hp at 15 psi. I would go bigger hot side and vac cam.
    Build Thread
    http://www.e30tech.com/forum/showthread.php?t=84988
    "When In Doubt Boost It Out"
    ~89 325I Turbo 11.90 @ 121~
    ~ 420whp/420tq~
    15psi
    ~Paul Burke Built 2.8L Stroked M20
    ~666 Divided Mani T3
    ~6262 T3 Turbo
    ~O'ringed Block SS
    ~Custom Fuel System
    ~3'' Turbo Back
    ~50mm Tial Bov
    ~Dual Tial 38 Gates
    • sayed ali
      • 762
      Great! What's your motor specs? Pistons, rods, .. ?
      M20B28 Turbo
      My Build Thread
      • sayed ali
        • 762
        ^ Which cam are you going to run? Mild grind or aggressive grind?
        I've just e-mailed vac tech about that but still no answer ..
        M20B28 Turbo
        My Build Thread
        • beefjurky69
          • 613
          Im running a Paul Burke built motor 2.8L
          Engine block bored to 3.327”, honed and O-ringed (039 stainless O-rings)
          2618 T-61 forged turbo piston set (approximately 8.5:1 compression ratio)
          4130 steel piston pin set
          Diamond finished “Total Seal” gapless piston ring set
          81 mm cast iron crankshaft
          Eagle 3D H beam connecting rod set
          Glycol main bearing set
          KS rod bearing set
          Laso oil pump
          Fully balanced reciprocating components
          Street turbo cylinder head porting
          Dual valve spring set
          New rocker arms
          New rocker shafts
          New adjusting eccentrics and associated hardware
          “Cat Cams” adjustable cam sprocket
          “Schrick” 284 camshaft (Paul Burke custom)
          Build Thread
          ~ 420whp/420tq~
          15psi
          ~6262 T3 Turbo
          ~O'ringed Block SS
          ~Custom Fuel System
          ~3'' Turbo Back
          ~50mm Tial Bov
          ~Dual Tial 38 Gates
          • sayed ali
            • 762
            Mean specs, and thanks for your kindly help .. so what do you think of my motor specs? should i go with a better turbo and see what could i make, then if i didn't satisfied, upgrade to a turbo cam?
            M20B28 Turbo
            My Build Thread
            • sayed ali
              • 762
              Are you running ARPs head studs? Do i need them up to ~450whp?
              M20B28 Turbo
              My Build Thread
              • beefjurky69
                • 613
                Yea I run arp's torqued to 70 ft lbs...My buddy Bobross who's on this forum has a stock motor Arp's on a holset making 460whp and high 300 tq
                Build Thread
                ~ 420whp/420tq~
                15psi
                ~6262 T3 Turbo
                ~O'ringed Block SS
                ~Custom Fuel System
                ~3'' Turbo Back
                ~50mm Tial Bov
                ~Dual Tial 38 Gates
                • TheTacoMan
                  • Nov 2011
                  • 2308
                  I wouldnt run that ebay turbo, just start out with the right stuff from the beginning.
                  • sayed ali
                    • 762
                    +1, thanks guys, seems like I'm going with a better turbo, but there is another one comes up in my mind .. BW s366, T4, .88, Billet ..
                    What do you guys think?
                    M20B28 Turbo
                    My Build Thread
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      It depends what you want as far as drive ability versus peak horsepower. Also I would look into a turbo cam, m20 stock cams fall on their face after 5k.
                      • Q5Quint
                        • Jan 2005
                        • 725
                        When you double the hp of a stock motor, there are a few things to look at closely.
                        Mainly ecu/ignition/fuel upgrades
                        Followed by hardware upgrades. (ie what breaks first?)
                        Turbo piston, pins, crank upgrades etc are great for longevity, but stock stuff seems to hold up to plenty of boost abuse as well. Not the headgasket, though. The stock intake will hold power, but an upgrade there can get you more. Old stock components become a liability with age, so 'if its open might as well' can help the long term survivability of the hardware. The hardware, no matter how good, wont survive with bad software, so make sure to get that right.
                        • SLEEPYDUB
                          • 658
                          KS rod bearing set
                          Laso oil pump
                          New rocker arms
                          New rocker shafts
                          Do you have a dyno graph that shows when you hit your boost targets?
                          - AXIS POWERS - 2JZ E30 Build
                          Current Project - 87 325is 2JZ Swapped with M4 DCT
