Which gauges to get for M42 Turbo?
  • MrSlacker
    • 2494
    I am installing Jackb's turbo kit on my M42. Which gauges should I get? I know AEM and VDO makes good stuff, but I don't know if there is a difference.
    So which 3 gauges should I get and why?
    Thanks!
    My Seller/Buyer Feedback
    Performance Aftermarket Parts & Accessories
  • ak-
    • 12422
    You're talking digital vs. needle here for the most part.
    I use VDO because I like the interior of my car OEM looking.
    Oil pressure, oil temp, vacuum/boost, & water temp because the stock one is useless.
    I'd say pressure is the least important because you still have the idiot light on the cluster for anything <5psi (?).
    1991 325iS turbo
    • BMWManiac
      • Dec 2010
      • 1091
      I agree with above:
      MUST HAVE BOOST and AFR minimum! I recommend analog gauges (I have my AFR in my driver side vent) and get the boost gauge that replaces your econometer!
      Then, water and oil temp so you really know when your motor is ready for boost!
      1997 Artic Silver M3
      CES GT4094r 651hp/615tq @ 24 psi
      • ak-
        • 12422
        I thought I noted AFR, but guess I didn't. He's right. Boost and AFR are probably the most important ones. My boost gauge has saved me twice from blowing my motor - Once from a torn wastegate diaphragm and the second time from my boost controller's vac line coming off.
        1991 325iS turbo
        • george graves
          • 19996
          Originally posted by Matt-B
          • G FORCE
            • Mar 2014
            • 159
            On my turbo cars I would always have AFR, Boost & EGT all with peak/hold and or logging options.
            Gabe
            '91 318is
            • cleanasse30
              • Jan 2014
              • 436
              Yo, any more details on where i might find this?
              2.7i Stroker Turbo Build Thread
              90 325i | 95 Miata
              • BMWManiac
                • Dec 2010
                • 1091
                He makes them
                • ccsdo5
                  • Mar 2013
                  • 707
                  I would say the three tops for me are AFR, boost/vacuum, and oil pressure.
                  But it depends what you want to know. Eventually I am going to run AFR, boost, oil pressure, oil temperature, exhaust temperature, and coolant temperature just because I want to know what's going on with my engine since it'll probably be seeing lots of abuse on the track.
                  -Dee
                  5-lugged turbo 318is Barn car
                  IG: @deebelmont
                  • CorvallisBMW
                    Long Schlong Longhammer
                    • 13039
                    Turbo-specific would be:
                    A/F ratio
                    Boost/vacuum
                    Also good ideas (since you're going to be putting more stress and demand on your engine) would be:
                    oil temp
                    oil pressure
                    water temp
                    The VDO 'Vision' series matches the OEM e30 gauges very well. As an example I'm using George Grave's A/F gauge, replacing the stock water temp gauge with boost, and adding the remaining three to a 3-gauge pod in the cubby space in front of the ash tray.
