Bit off way more than I can chew with this project, but no sense in quitting now... Already have a roadblock just trying to mount the inter cooler. I have a 27x7x2.5. The radiator(?) fan was in the way of fitting so I just removed it. Is that okay or was it stupid? What should I mount the ic to? Is it standard to fabricate some sort of bracket? Goal was to have no visible trimming and keep my ac... Now I just want to get it completed so I can experience a turbo e30.
Need help fitting inter cooler
We removed the aux fan and fabricated some mounts....you can check out my build thread to see what we did. We also notched the frame so run the a/c lines. The a/c isn't the coldest, but I did have to eventually turn the a/c off while driving. If you need help with some of the work, I had a great experience with the folks at Spec Ops Motorsports on Raeford Rd past Skibo....right next to O'Reillys1997 Artic Silver M3
CES GT4094r 651hp/615tq @ 24 psi
