so over the weekend I installed all my turbo stuff on my s50, when i start the car it runs and drives great for the first 10 mins but once it's fully warmed up the idle really fluctuates a lot to the point where it Almost stalls out, when this happens the a/f shoot up to 18-19 and the vacuum fluctuates from about 20 down to 15.
What I have done so far is went over the entire vacuum system all my
Lines are set up in the correct orientation for a turbo car, it doesn't look like I have any vacuum leaks
The motor was running great prior to the turbo install with a steady idle when warm and compression test was all within spec
I am thinking this is an issue of once the ecu goes into closed loop, but I'm not too sure what to start with, I am going to do a leak down test along with a smoke test to see if that will show any issues but I'm thinking it could be a bad o2 sensor maybe? Any help would be appreciated I did a few pulls with the car it holds boost great and a/f ratios seem safe under load
