Just wanted to run this setup by you guys before i installed it and comfirm it will be suffecient and do the job!
M20 turbo on 12psi tuned via megasquirt and currently running a hose from the valve cover to the ground and venting to atmosphere and the fumes and vapor gasses are starting to become obnoxious!
I plan on running a hose from the valve cover to a sealed catch can, then a hose from the catch can to a one way check valve that screws into a metal bung that i have welded into my downpipe at a angle where it will create vacuum to pull the vapors from the crankcase and exit them out of the tailpipe instead of to the intake side, where i would worry about the gasses and fumes entering the turbo inlet and causinf issues as most people describe.
I have heard the discussion of peoples concerns in regards to not pulling enough vacuum through the exhaust but i am running 3" straight pipe from turbo back with no cats or mufflers... I will also be hooking up a vacuum gauge to test functionality and comfirm vacuum is present and suffecient.
Can anyone comfirm or have experience with this specefic setup. Any help is appreciated!
