Early Model Fuel System Upgrade
  • BenjaminButtton
    • May 2012
    • 275
    To the guys running higher hp in early model cars - what's your fueling setup?
    Need to feed about 400hp or so, and I'm having trouble finding the best setup with the two-pump system the early model has.
    For example - I have a Walbro 255 lift pump.. Do I use an OEM main pump or match the in-tank with a 255lph main pump (exterior/in-line pump)? Or something else entirely?
    Early models do it better.
    '86 Cosmos Sedan LS1
  • TheTacoMan
    • Nov 2011
    • 2308
    Replace the main pump, and delete the in line pump if using pump gas.
    • BenjaminButtton
      • May 2012
      • 275
      I've heard from several people that this causes fuel starvation below half a tank - are they doing it wrong?
      • the imitator
        • May 2013
        • 1006
        Ill be using an 034motorsports surge tank.
        • BenjaminButtton
          • May 2012
          • 275
          Such as this?:
          Assembled Kits BACKORDERED: Orders placed today will hold your spot in line for the next available units, Mid April 2026 ETA 034Motorsport is proud to offer the FP34 - the most advanced Bosch 044 fuel pump installation solution available. This beautifully-designed surge tank fully encloses a Bosch 044 fuel pump inside a 1 liter reservoir, and allows for flexible mounting location while ensuring optimal flow. PLEASE NOTE: FP34 Fitting Kits (AN or Nipple Connection) are available separately below. An extra steel M12 adapter is included to account for discrepancies in aftermarket pump lengths. Use the adapter that best works for your pump length to allow a proper fit in the FP34 housing.
          The surge tank would take place of the factory main pump (in-line) and you would be able to run the factory lift/transfer pump?
