TCD S-2 intercooler reservoir leak - JB Weld or?
  • Dave McLaren
    • Jul 2006
    • 593
    The TCD S-2 system uses a water-to-air intercooler. The reservoir was mounted such that it was touching a body seam in the front clip which chafed against the aluminum reservoir causing a leak. Can I use JB Weld to fix the hole or what is recommended?
    I'll try to add a pic and hopefully YouTube link in a minute. Want to get this up first as I typed up the post on my iPhone 6 then the page crashed.
    Thanks, guys.
    Dave
    Present BMWs: E30 325iC, E39 540 Sport 6-speed, E60 M5 SMG
    E30 Cabrio Turbo Project
  • LJ851
    • 7918
    Weld it.
    Epoxy like JB weld is a temporary repair if it works at all.
    Lorin
    The M30 is God's engine.
    • Dave McLaren
      • Jul 2006
      • 593
      Originally posted by LJ851
      Weld it.
      Thanks, Lorin. I was thinking that but wondered if i could doctor this thing up at home today.
      • ak-
        • 12422
        I would also like to weld it, but JB weld will definitely work.
        Just sand it down bare all around the area and let it cure for 12(?) hours or so.
        1991 325iS turbo
        • TheTacoMan
          • Nov 2011
          • 2308
          You can also bend that sheetmetal or cut it pretty easily.
          • Dave McLaren
            • Jul 2006
            • 593
            Got the hole welded up today and it looks good to me. I guess I'll touch up the powdercoat texture with a bit of matte black spray paint I have in the garage.
            • Dave McLaren
              • Jul 2006
              • 593
              By the way, thanks for the tips ak and TheTacoMan.
              I don't want to cut any sheet metal so I think I'll start by putting some rubber pieces as a buffer between the reservoir and the body. If I do a crap job of that, I'll get engineering in my factory to figure it out.
