2.8L M20 Turbo Build Question
My 2.8L stroker was built in the year 2000, so I am not sure it will be much help, but I am running Mahle Pistons for low compression1987 325is 2.8L Stroker Turbo "Little Pickle aka The Green Turbo Sled"Comment
So I've decided to go with:
-M52B28 Crank
-CP 84.5mm bore 9.0:1 compression pistons for the the M52 crank and 135mm rods
-135mm SP Components (VAC) Rods
-VAC Performance main bearings
-VAC Performance rod bearings
-VAC Oil pan baffle
-All needed oem gaskets from VAC
-Crankshaft spacer
Hopefully this should do the trick
Sent from my iPhone using TapatalkComment
