Hey y'all,
Finally some good news with the build! Tonight I hit 9psi! My wastegate spring is set to 8psi. I only got one run hitting 9psi as my rubber intake boot popped. I am replacing it with silicone once my megasquirt comes and am deleting my ICV.
I was not able to make more than 5psi until tonight. I made one change. I plugged the top port of the wastegate. I have the bottom port hooked up to a tap on the turbo.
From my online research, I am supposed to leave the top port to atmosphere. A local turbo guru told me to plug the top port.
The wastegate is a 44mm v-band CXRacing.
Can somebody please clarify how to run the vacuum lines?
Thanks!
Thanks!
