m20 Stroker Hx35 1/8th mile videos
  • etagolnik
    • Nov 2012
    • 105
    Went to the local 1/8th mile track last weekend and got some videos from inside and outside the car. Check em out!
    Against a duramax lol:
    Infinity q50 twin turbo kill!
    Warming the tires ;)
  • LowR3V'in
    • 4209
    That's cool. antilag is a hell of a drug.
    Whats the story on this? tell us more about it.
    • etagolnik
      • Nov 2012
      • 105
      The car is a 1987 325 (non-I) with:
      - 2.8ish stroker
      - Ross forged pistons
      - eagle forged h beam rods
      - stock crank
      - myster-e head with 272 grind and heavy duty rockers
      - mls gasket with ARP studs
      - whodwho microsquirt
      - hx35 from a Cummins generator
      - 9-12ish psi depending on load
      Plans are meth and 20 psi at least
      • Turbo E30
        • Jun 2016
        • 13
        What axles do you plan on using, with any grip your stock ones will be breaking quickly.
        • etagolnik
          • Nov 2012
          • 105
          Stock axles. I’ve broken one so far but that’s the only option for e30’s besides changing the rear subframe to a z3
          • LowR3V'in
            • 4209
            2 other option.
            Get top-quality crankshafts, connecting rods, and forged pistons at PPM Racing. Our cutting-edge technology, including CNC machining and computer-aided solid modelling, ensures maximum strength and weight savings. Choose from 2618 or 4032 grade aluminium alloy, with hand de-burred pistons and precision-milled ring grooves for low-drag, lightweight performance. Experience the best in design and manufacturing with PPM Racing.
            • etagolnik
              • Nov 2012
              • 105
              Those prices are insane though.. Stock axles will be fine for me
              • 808e30325i
                • 537
                Just learn how to preload and you will be fine.
                • LovelessAndroid
                  • Aug 2012
                  • 25
                  Cam Grind
                  How do you like that 272 grind cam? Is it good for the 10 psi setup or did you just kind of keep it because you had it?
                  • SLEEPYDUB
                    • 658
                    Ok so what were the times and traps?
                    - AXIS POWERS - 2JZ E30 Build
                    Current Project - 87 325is 2JZ Swapped with M4 DCT
                    • etagolnik
                      • Nov 2012
                      • 105
                      272 is fine. I cant remember if its a 272 or 274. Its a decent cam for daily driving.
                      • etagolnik
                        • Nov 2012
                        • 105
                        Not sure about my traps but I think my fasted time was 8.6s or something.
