So, I’m having a bit of a dilemma trying to weigh my options for a turbo 24v swap. My initial goals are 4-500hp on stock bottom end, with spacer and cut ring hg, and whichever size turbo is appropriate. My two leading choices are m52b28 with m3 cams (plus hg/spacer) or s52 with same hg setup.
Both engines are available near me for good prices. The m52 is lower mileage and said to have been running before removal. The s52 is about twice the price with 200k miles and has a (likely) blown head gasket due to an overheating issue that was easily resolved by replacing an old coolant line, but was said to be running fine for a short period and not overheating, except for some coolant residue in the oil cap. The s52 also came from an auto.
The price difference between the two would easily be made up by the cost of s52 cams to put in the m52, making it an easy choice to go for the extra displacement if not for the hg issue, but I’m obviously wary about any damage that may have been done to the s52.
So, is it even worth considering this particular s52? If it is worth, what are some key things/areas to inspect on the s52 before and after pulling the head? (I was given permission to inspect whatever I need before purchasing). Or should I just say screw it and go with the m52?
This work in (slow) progress will be the happy recipient:
1990 325i
