HKS additional injector controller problems
  • blueapplesoda
    • Dec 2005
    • 1904
    HKS AIC
    Im using the stock injectors plus the two injectors mounted via intake stream.
    My problem is that my additional injectors seems to be stuck open when the car is in any on position. All of the wires go to where they should go to.
    btw i just pulled this entire fuel system from my dads e36 m3 turbo so it was working when i pulled it.
    I try to start my car but it just cranks over and over and smells raw fuel everywhere. So i know the injectors are just spraying away. So i unplug the two injectors and voila my car fires up and idles smooth.
    while its idling, i plug an injector in and put put die the car dies. I hear the remaining pressure from the fuel line squirt into the intake pipe.
    Does anyone know how i can fix this stuck-open injector problem?
