M30 turbo running too rich only on boost
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    So I finally got my M30 turbo finished and exhaust done. So i took it for a drive today and it runs fine off boost. I have an LM1 and on idle and daily cruising, i'm running 14.5-14.8 AFR, so i'm not concerned with that. I tuned my AFM and am satisfied... OFF BOOST.
    Once I boost it and it gets in the higher RPM's, I start to run 10AFR and 9.2 was the lowest. At that point, the engine stutters and kind of gives up. Hesitates and dies. In other words, boost sux. I'm running 9psi. I turned my RRFPR all the way clockwise to tune for the least amount of fuel pressure on boost and it's still giving me 9.2 A/F. What's the deal and how do I fix it??
    Are my spark plugs not firing on boost???
    I'm not adjusting my AFM again, I got it back 25 clicks and it's idling perfectly.
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
  • backtrail69
    • Jul 2005
    • 4471
    What setup are you running? I am sure Todd from TCD can help you out with your problem. Give him a call at: 614-734-1422
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • Garageaholic
      • Dec 2005
      • 5204
      Yeah, i know. He's not there right now. I can't get ahold of him. Thanks
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      • Erick
        Official R3V Drifter
        • 11169
        Easiest fix? Up the boost. :)
        ..::Support FullOpp::..
        FullOpp Stickers for sale!
        Feedback Thread
        • Garageaholic
          • Dec 2005
          • 5204
          hahaha, i'll blow my HG! I'm already running at around 8-9psi w/ stock HG.
          It boosts nicely only until i get above 4krpm, where the HP really kicks in, but it just stutters and uber-riches up. It's frustrating and I hope it's an easy fix. I"ll try to get in touch with todd tomorrow and see if he has a suggestion I haven't thought of.
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
            • 37834
            Try swapping the stock FPR back in maybe?!
            Grover Beach, California
            BimmerHeads.com
            • Garageaholic
              • Dec 2005
              • 5204
              I figured it out. It turns out that I didn't put a restrictor in my vacuum signal line into my RRFPR. Toning that signal down really lowered the fuel pressure at positive manifold pressure. I'm good. Thanks guys.
              Recent Rebranding!!
              E30 SM62/S62
              E30 M60 V8
              E30 M30 Big 6!
                • 37834
                Nice.
                BimmerHeads.com
