Need Help On Turbo!
  • E30BIGTURBO
    • Sep 2007
    • 27
    Need Help On Turbo!
    What do i do about the vacuum lines.. and all this extra stuff i dont need..
    Stock ECU nothing else.. 8-10lbs of boost not even.
    and something about the crank case ventilation????
    DO i run the BOV infront of the throttle body or ?????
    DO i run the Air flow meter infront of the TUrbo inlet?? orrr the throttle body.
    Im using 30lbs low imp injectors.. Rising rate FPR, colder plugs,and
    what is the exact 255 fuel pump i need to run someone said there are differnt kinds..
  • whiltebeitel
    • Apr 2007
    • 2098
    Keep the vaccum lines. You need them.
    Run the BOV in fron to the throttle body, behind the compressor.
    '89 325i track sloot
    '01 530i daily
    -Enginerd
