I have a 323i Mtechnic E30 86 with the normal gearbox i wanted to install a turbo... i can customize my kit here in peru, because here there is no kit available...i wanted to ask and if somebody could help me, i have hear that the engine can resist 8-10 psi its that correct? if i install it on 8 psi how much HP i would gain and if the gearbox would handle that amout of torque thanks from peru
E30 323i Turbo project please HELP(i have read various topics already)
I'm not sure what the compression is on a 323i, but I would think that 8-10lbs would be OK on a motor in good condition. You could expect about a 100hp gain, more with a standalone engine management/tuning/intake/exhaust/intercooler/etcComment
If the CR it's 8.8:1 you will be fine up to 1 BAR reliable (sp?), but get a stand alone system. Tranny stuff will hold the extra abuse fine except the clutch/pressure plate.Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
The getrag 260 gearbox is really robust. If it's in good condition, it's the last of your worries. You will need an upgraded clutch though. You can search on this site to find more info on which clutch you should go with.
Edit: Oops. I thought the 323i came with a 260. 240s do have problems holding power.Last edited by Jordan325iC; 07-05-2008, 11:31 AM.
'88 325is
VP UT of Austin Autoholics
BMWCCA 380364Comment
So a tranny in a 89 325 in good condition would be fine with a boosted motor? How about the rear end?The getrag 260 gearbox is really robust. If it's in good condition, it's the last of your worries. You will need an upgraded clutch though. You can search on this site to find more info on which clutch you should go with.
Edit: Oops. I thought the 323i came with a 260. 240s do have problems holding power.Comment
