e30 m20b25 ebay turbo kit?????
  • wwwayn
    • 22
    :?:does anyboy running an ebay turbo on your m20b25 ?
    i need some input to buying a turbo kit.
    my buget is about 1500-2000
    can i use oem stuff.(ecu/injector/afm)
    anything elsei need to make it work?
    i am just looking to add about 30-50 hp, i think ebay turbo kit will work.
    thanks
  • Aptyp
    • 6584
    too many turbo cars there and some people run ebay kits.
    • zenn0ne
      • Jan 2009
      • 119
      ebay kits are garbage unless you go with 666 fab adapters or cast iron turbo manifolds
      the kit i got cracked while i was installing it on my car.........pissed me off......so i went with a m52 turbo setup and cant wait 2 put it together........500whp=goal
      sigpicBEST OF BOTH BOOSTED WORLDS
      • Jordan325iC
        • Aug 2005
        • 1697
        With your level of experience, $2000 for a turbo setup is not a realistic goal. Things add up crazy fast, even if you are going with a low-boost setup. On top of the kit, add on fuel managment, injectors, clutch, full exhaust and downpipe and you've easily doubled the cost of the kit. More if you're not able to tune and weld yourself. And that doesn't involve the 500 trips to autozone or little orders from summit racing. I have probably more than doubled my initial budget calculation, and I'm still needing things. If I did it again it would be much cheaper, but the first time is always an expensive learning experience.
        Also be aware that the ebay kit isn't as much of a "kit" as it is a collection of random ebay crap. The manifold is made for the m20, everything else is generic and will need to be custom fitted. The quality of many of those pieces is suspect. You might be better off buying high-quality parts where it matters (turbo, wastegate, manifold) and buying cheap things where you can afford it (intercooler+piping, exhaust bends, bov).
        e30tech.com is the place for turbocharging the m20 (although you should search before you ask that question).r3vlimited is more of a place for engine swaps.
        On that note, if all you want is another 30-50hp, have you considered an m50 or m30 swap? Those engines can produce the extra power you are looking for, and can be swapped in for $2000 with careful shopping. Better reliability too.
        '88 325is
        VP UT of Austin Autoholics
        BMWCCA 380364
        • EvoStevo
          • 173
          You're saying that the turbo manifold cracked as you were installing it? Where exactly and how? If other people using this manifold could chime in as to its build quality and durability, I'd greatly appreciate it.
          • Danny
            • 14216
            Piece it together.
            • Kingb
              • 928
              Do what Jordan said. Swap for a M30 or M50. You must be one of those guys that just wants to brag that they have a turbo'd E30 to all your friends
              Originally posted by Nicademus
              My car beats off to that car. :bow:
              • ubernasty
                • Jan 2009
                • 2749
                lol for real...if you want to turbo do it right (the FIRST time) or its not even worth the wasted time and money
                • blueapplesoda
                  • Dec 2005
                  • 1904
                  shameless plug--
                  check the link in my sig!!
                  site isn't complete..but its half there!
                  • fiercee30
                    • 199
                    idk i heard ebay kits were pretty cheap and not too bad
                    84 ETA
                    • hugh jass
                      • 2220
                      great post man
                      ______________________
                      ex-Chief Operating Officer
                      Blunt Tech Industries
                      West Coast and Pacific Rim
                      • Danny
                        • 14216
                        You are an asset to the E30 community.
                        • kronus
                          • Apr 2008
                          • 13020
                          You should receive the Presidential Medal of Stuff
                          cars beep boop
                          • fiercee30
                            • 199
                            hahah thanks...kronus you are right i am a good asset to the E30 community. heard that the ebay turbos are good for the price.you get what you pay for thats what i met to say?
                            84 ETA
                            • Adrian_Visser
                              • Jun 2006
                              • 2823
                              Way to revive an almost one year old thread.
                              '89 Alpine S52 with goodies
