i did a quick search and came up empty handed
how much boost can i run on a stock seta stroker.
stock hg, i am assuming stock everything else since i did not build the motor.
there is mild port work on the present head and a 293 dur cam.
i am going to use an M-90 super charger and blow through my Dbilas (yes they will seal, i emailed them first)
i am going to try to do this w/o diving too deep into the engine if possable. if not i will open it up.
i am looking to run between 10-15 lbs of intercooled boost max.
thanks
thanks
